Anders, when you snapped your BX one, did it bend at all or did it break cleanly?
If it was a clean break with no bending whatsoever, thats what cast does. If it bent first i.e. the two pieces didn't fit together perfect, there is no way it could be cast iron. Cold weather can make metals that are normally quite ductile go brittle...
My mother's old '85 MKII VW Jetta had pressed steel bottom links on its suspension. I don't know whether you'd consider 1985 to be vintage...
Bent wishbone
Kowalski, it snapped into 2 pieces [:)]
- one of the "legs" holding the bushes snapped right off.
I have no factual info if it is cast or forged iron. I just assumed it was cast iron by the look of it. But you're right that cast iron presumeably would be "too crisp" as a suspension component, given the forces (and acceleration hereof) existing here.
Mind you the speed at impact was around the 45Mph mark. In fact the offended front wheel ended up pressing against the door pillar - after compressing the rear part of the front wing.
