CD multichanger
Hi there, I ran my cabling down behind the radio etc, then under the centre console (by taking out the rear ashtray and front tray and undoing the four nuts, then after removing the rear seat cushions ( 4 nuts) I pulled up the carpet and insulation and pushed a wire (the good old straightened wire coathangar with a loop on the end !) under the carpet and pulled the wire(s) through.
Well, I managed to get it in. I fed the wire behind the head unit, down and under the glovebox. Then pulled the door seal off at the bottom, and fed the wire under the carpet all the way along till I hit the rear seat. I then had to make a minor modification by cutting a small slot in the metal that the seat bolsters onto so that the wire could enter the boot without catching, and come out through the hole for the bolt that holds the seat up when not hatched. The changer cage was then screwed to the rear of the seat. Job done! The only thing is, some songs make the speakers crackle with the bass....not sure what's causing that.... Hmmm....
