Before going the whole hog and replacing the motor, I would at least take the head off first anf give it all an eyeball.
You can spin the motor over and see if the pistons all go up and down as they should. They should all reach TDC at the same height and if they do then you can rule out a bent or broken conrod. if that checks out o.k. then you may have been lucky and got away with a couple of bent valves, which with the head off you will be able to check for and sort.
River damage!!!!!!!!!!!
Have a mate with a 306 1.9td who went through a deepish puddle. The car kept going OK for a while after until it dropped a valve. It seems that the vavle stem got fractured with the water entering the engine but didn't actually break until a while later. Result was a bent con rod and damaged cylinder bore. So, even though the engine might seem OK there may be hidden damage somewhere.
I'm always reluctant to assume the worst. A compression test may tell a lot.
When my DS sank into the sandy bottom of the Daintree River, water got into the engine oil. Removed oil filter, flushed briefly with light oil, and then installed new filter and engine oil. 120,000 miles later, the engine was still like new. Mind you, I've yet to experience hydraulic lock, and I now put my chains on BEFORE taking the car through a river bottom.
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by peter1138</i>
Protected NCB means you won't lose your bonus. However, you'll still be lumbered with a higher premium for having made a claim...
Yeah thats the thing with this protected no claims, hyou still have to declare any details of any accidents/claims youve had so still end up paying extra. I dont think the protected ncb is worth it to be honest.
Cheers
Paul
Cheers
Paul
Having carefully considered all the options such as the cost of fitting an engine £200-£300 then having to source said item £500 i have decieded to give mr insurance company a call, they are collecting the car tommorow. the other factor was that all of the carpets are soaked. thanks again for all of your help and if anyone knows of a nice hdi exclusive estate let me know!!!!!
