My Xantia Activa has no compression on No 1 cylinder. I have no loss of oil, no loss of water. All the other cylinders show 75 - 90 ps, as expected for the turbo engine.
Is this engine known for this problem? If yes, what is the problem, gasket, valves, camshaft, etc? I would appreciate a little guidance from those in the know before I start to strip down the head.
xantia 2.0 8v engine problem!
- fastandfurryous
- Location: On the road, travelling at high speed. Meep Meep.
- x 4
If it really is NO compression, then I would suspect a valve to be jammed open. If the compression is just very low, then look at a head gasket. If it is only a bit low, then possibly worn out rings. The only way to be sure is via a leakdown test, which involves piping compressed air into the cylinder via the spark plug hole. You can usually then hear the air escaping by either the exhaust, inlet system, gasket face, or breather system.
It is entirely possible to do this test yourself, by sacrificing a spark plug, welding a nut into the shell, cutting a thread on an old tyre valve, and screwing the whole lot together into the head. I've done this sucessfully a number of times in the past, and it is very revealing.
- fastandfurryous
- x 4
As this is a turbocharged petrol engine, with a compression ratio of about 6:1 I think 90psi is about right. On a 9.5:1 Naturally aspirated engine you would expect 140psi.
Do a leakdown test, on ALL cylinders. Best to do it with the piston at TDC (obviously between compression and ignition rather than between exhaust and intake![:D])
Thanks for the info, fastandfurryous. I have given the car to my local garage to take the head off to investigate, as all the possible scenarios point to an internal defect of some type. The mileometer reads 130K but I do not have any docs to prove mileage. I had at first suspected cambelt problems but up until this occured, the car was running extremely well with excellent power characteristics.
I was wondering if there was general knowledge of these engines' inherent weaknesses, like wearing rings, holing pistons, loosing valve heads, etc.
Anyway, all will be revealed shortly.
- My Cars: C5 X7 2.7 hdi
Past cars
Activa, silver MK1 (221bhp stock) stripped out with twin sparcos Evo seats. 95
Activa, light met red MK1 98
Activa, dark met red MK1 98
Activa, dark met blue MK1 (202bhp stock) 96
Xantia exclusive V6 auto 3l 98
Xantia 2l 8v auto
BX 4x4 GTi dark met silver
BX 4x4 GTi white
BX GTi 16v white fibre bumpers
BX GTi 16v black fibre bumpers
BX GTi 16v hurricane (doa)
BX DTR estate
