Hi all,
I posted a couple of weeks ago about the way to solve rattles (sounds like a loose heat shield) on the above mentioned models. If you get a rattle when your decelerating or in low revs (1250 - 2500) your upper engine mount has problems. Because so many Activa owners have this problem (including my wife) I have done some work on this.
Firstly its not a particularly hard job I just did it in 20 minutes with only a 16mm spanner and a new mount (the old ones centre was removed by hand that’s how badly it had failed).
because this is something that needs pictures and is a common problem that seems to hit at around the 8 year mark (mileage doesn’t seem to matter) I will create an article on www.activanet.co.uk under the repair section (which doesn’t exist at the moment).
Andy
xantia CT, V6, 2.1TD and HDI 110 owners read this.
- My Cars: C5 X7 2.7 hdi
Past cars
Activa, silver MK1 (221bhp stock) stripped out with twin sparcos Evo seats. 95
Activa, light met red MK1 98
Activa, dark met red MK1 98
Activa, dark met blue MK1 (202bhp stock) 96
Xantia exclusive V6 auto 3l 98
Xantia 2l 8v auto
BX 4x4 GTi dark met silver
BX 4x4 GTi white
BX GTi 16v white fibre bumpers
BX GTi 16v black fibre bumpers
BX GTi 16v hurricane (doa)
BX DTR estate
Past cars
Xantia 2l 8v auto
BX 4x4 GTi white
BX DTR estate
Past cars
Xantia 2l 8v auto
BX 4x4 GTi white
BX DTR estate
