I have been lead to believe the "Bi-tron" is located under the LH headlamp somewhere but I've looked and I'll be buggered if I can find it but apparently it's there.
Alan S
Aircon compressor query
- Contact:
From what I remember of trying to fix mine you have to remove the passenger side headlight to get at the Bitron
Pete
________
Medical marijuana grow
Pete
________
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by Kowalski</i>
I had a good look for my Bitron.
Its not on the engine side of the inner wing or in fact under the headlight, so I don't know where it is. It could be inside the wing (between inner and outer) but I can't see in there really.
There's a box under the keypad immobiliser that I think is the aircon unit, accoring to something I read - maybe haynes! Perhaps the bitron unit is seperate still. I think there's also another one adjacant to the handbrake.
That mystery fuse - it's marked F3 in the haynes book, but it's located not in the dashboard fusebox NOR in the engine compartment fusebox which are marked seperately, but in the "supply box", a third place for fuses. Or at least that's how it seems, it's hard to read any other way.
- My Cars: C5 X7 2.7 hdi
Past cars
Activa, silver MK1 (221bhp stock) stripped out with twin sparcos Evo seats. 95
Activa, light met red MK1 98
Activa, dark met red MK1 98
Activa, dark met blue MK1 (202bhp stock) 96
Xantia exclusive V6 auto 3l 98
Xantia 2l 8v auto
BX 4x4 GTi dark met silver
BX 4x4 GTi white
BX GTi 16v white fibre bumpers
BX GTi 16v black fibre bumpers
BX GTi 16v hurricane (doa)
BX DTR estate
Past cars
Xantia 2l 8v auto
BX 4x4 GTi white
BX DTR estate
ok according to the xantia owners manaual... there are 2 F3 fuses. 1 is in the dash (not the one you want) the seccond is in the engine fuse box this is the one located directly behind the batery it should be the left hand botom fuse closest to you if your looking at the car fron the passenger side front head light.
The hayens manual dose make me wonder as there is significat diference between the 1.9td/Ct/2.1td AC looms (as a sample) and the imputs the ECU's use on the latter 2 arent even the same!
Andy
Andy
Past cars
Xantia 2l 8v auto
BX 4x4 GTi white
BX DTR estate
