xantia ride hight... - the facts
- Kowalski
- My Cars: Ex 05 C5 2.0 HDI Exclusive 145k
Ex 97 Xantia 1.9TD SX 144k
Ex 94 Xantia Dimension 1.9TD 199k
It has estate front brakes, aircon, alcantara seats, a rear spoiler, mudflaps as well as body coloured bumpers (the inserts that are normally grey have been painted body colour). My Xantia would probably be one of the last prefacelift Xantias produced so its been fitted with a load of kit that the other one doesn't have. It was registered on the last day of 1997 and run by Citroen UK for 8 months before being sold.
There seems to have been two different rolling radiuses fitted to Xantias. The 185/65/15 and 205/60/15 are roughly the same radius, where as the 175/70 R14, 185/65 R14, 195/55 R15, 205/55 R15 are about the same. The different radiuses would need different speedo setups and would give different gearing, performance and fuel economy, I know my later Xantia doesn't seem as fast as the earlier one although it is more economical (different turbo, different Bosch fuel pumps and different mileages).
- My Cars: C5 X7 2.7 hdi
Past cars
Activa, silver MK1 (221bhp stock) stripped out with twin sparcos Evo seats. 95
Activa, light met red MK1 98
Activa, dark met red MK1 98
Activa, dark met blue MK1 (202bhp stock) 96
Xantia exclusive V6 auto 3l 98
Xantia 2l 8v auto
BX 4x4 GTi dark met silver
BX 4x4 GTi white
BX GTi 16v white fibre bumpers
BX GTi 16v black fibre bumpers
BX GTi 16v hurricane (doa)
BX DTR estate
Aircon was pretty much standard for the 1997 cars (they actually released a pamphlet on this) I always like end of phase cars they have so much more on them. Sounds like you have a real beauty, with some nice components.
I will try and collate all this info together and add it to the page soon. I was going to add the info for the rear axel but then at the end of the settings it says it cant be adjusted! So I didn’t see the point.
Is this actually helpful or just more confusing for people? I believe that when accurate info is available it needs to be shared but sometimes I just think its adds to the confusion.
Andy
Andy
Past cars
Xantia 2l 8v auto
BX 4x4 GTi white
BX DTR estate
Past cars
Xantia 2l 8v auto
BX 4x4 GTi white
BX DTR estate
http://activa-all.pwp.blueyonder.co.uk/ ... ssures.htm
bit of a suprise after the phase 1/2 change over the wheel/tires combinations didnt change so where did all these 1.9 1997 TD hatches come from with the estate setup? You guys between you share the vin numbers you may find they are very ver close. and then tell use how many cars out they are.
Andy
Andy
Past cars
Xantia 2l 8v auto
BX 4x4 GTi white
BX DTR estate
what tire preasures do you have with that setup? is it the same as the estate or diferent?
Also 15" make them alloys, what type do you have I am asuming these are VSX's or exclusives or are they a car that has had the alloys added as an optional extra? (and why arent they coverd in this documentation!)
Andy
Andy
- Kowalski
If you want an exhaustive list of which cars came with what tyres...
Check out the "servicing info" pages....
http://www.kolumbus.fi/perhe_pitkanen/xw/technica.htm
Past cars
Xantia 2l 8v auto
BX 4x4 GTi white
BX DTR estate
Past cars
Xantia 2l 8v auto
BX 4x4 GTi white
BX DTR estate
I've updated the fist page http://activa-all.pwp.blueyonder.co.uk/ ... onride.htm with the new data for setting up suspension baised on model.
Andy
Andy
Past cars
Xantia 2l 8v auto
BX 4x4 GTi white
BX DTR estate
If this helps, when the Xantia was launched, all models apart from the VSX came with 14" steel wheels. The tyres fitted to the VSX were 195/55/15, 16V ones may have had 205 width tyres.
In September 1995 when the 'new' 16V engines were launched, 15" wheels were made standard across the range with 185/65/15 tyres for all cars apart from 1.8 and diesel non turbo cars which retained 14" wheels.
