Hydro Pug!!!
Hydro Pug!!!
Just read that the Pug 405 Mi16 4x4 had rear hydropneumatic suspension?!? Did it sink down and rise on start up? Could ride height be ajusted? What were they like when compared to ordinary 405's to drive?
Yep - they had the BX rear suspension system and the height could be adjusted manually. Never drove a MI16.
Was not a performance suspension - but simply to maintain the correct rideheight for best stability to match the 16V engine.
BTW : Audi, Mercedes, RR & Bentley also have hydro suspension a la Citroen system [;)]
- for best drive comfort.
- My Cars: Current:
Volvo V60 D4 180
Previous:
BX16RS (two of),
BX19TZI,
Xantia 2.0i saloon,
Xantia 2.0 Exclusive CT turbo Break,
Peugeot 807 2.0 HDi 110,
Renault Grand Scenic, 2.0 diesel (150bhp)
C5 X7 2.0 HDi 160 which put me off French cars possibly forever - x 16
I seem to remember that some of the Peugeot 205 rallycars hydropneumatic as it enabled rapid damper changes to be made!
Of course the present Xara rallycar has the linked hydraulic suspension from Australia that seems to bear some similarities to BMC Hydrolastic! (I think the difference can be said that the Citroen system does not link the wheels but the BMC one does generally side for side - just like a 2CV!)
jeremy
jeremy
- fastandfurryous
- Location: On the road, travelling at high speed. Meep Meep.
- x 4
Does anyone know anything about the self-leveling rear suspension on a Merc W124? It has a hydraulic pump, and supplies fluid to what look like standard rear shocks. The problem with this car is that the rear has gone fairly hard, like a citroen with flat spheres, but I'm not sure if just changing the rear dampers (125quid +vat each from GSF!) will fix it. Any clues?
I would have posted this on the Merc forum, but the last activity on that was about 2 months ago.
[quote]<i>Originally posted by fastandfurryous</i>
Does anyone know anything about the self-leveling rear suspension on a Merc W124? It has a hydraulic pump, and supplies fluid to what look like standard rear shocks. The problem with this car is that the rear has gone fairly hard, like a citroen with flat spheres,[/quote hi, you will probably find that the height corrector rod has seized as in citroens, easy and cheap to fix mine in the past have gone, normally puts the rear end high at the same time,i'm with you on the merc forum - get your replies here!! a good check is to load up the rear and then start it up to see if it rises.
cheers
simon
cheers
simon
- Kowalski
- My Cars: Ex 05 C5 2.0 HDI Exclusive 145k
Ex 97 Xantia 1.9TD SX 144k
Ex 94 Xantia Dimension 1.9TD 199k
The JCB Fastrac has self levelling rear suspension.
Have a read of this...
http://www.atl-uk.com/documents/CompanyProfile2005.pdf
- fastandfurryous
- x 4
This merc doesn't have spheres. The damper looks like a standard unit, but with a hydraulic union on it's body. The ride has definitely gone very hard indeed, as noted by going over speed humps. Front is soft and damped, rear is like it has solid lumps of steel between body and suspension arms. If you load the vehicle up, the back end doesn't even drop, it's gone that hard!
I assume something has lost it's charge of gas somewhere, but I can't believe it's 125quid a side to fix that?? Haynes BOL is typically vague about the whole system.
The height of the back of the car appears correct... it could just do with some suspension movement!
