XUD lower Engine Mount
Yeah but im on about just generally cutting small amounts of metal in hard to reach places on a car, they crop up all the time. A dremel is the most versatile tool, but totally useless for cutting steel (or generally cutting), after that you have to resolve to hack saw blades on there own and other such useless stuff. I nice small 1" angle grinder would be pretty cool, so long as the body aint too huge!
My only problem with blades cutting the outer ring is that whilst the steel bit will cut slowly we all know that the alloy bit will cut like butter! and thats the part we want to keep, The hammer and chisel method (which was taught to me as part of my apprenticeship) certainly doesnt waste any time, an engineers vice will press the new one into place without difficulty.
Stewart
Stewart
- My Cars: C5 X7 2.7 hdi
Past cars
Activa, silver MK1 (221bhp stock) stripped out with twin sparcos Evo seats. 95
Activa, light met red MK1 98
Activa, dark met red MK1 98
Activa, dark met blue MK1 (202bhp stock) 96
Xantia exclusive V6 auto 3l 98
Xantia 2l 8v auto
BX 4x4 GTi dark met silver
BX 4x4 GTi white
BX GTi 16v white fibre bumpers
BX GTi 16v black fibre bumpers
BX GTi 16v hurricane (doa)
BX DTR estate
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by oilyspanner</i>
Stewart
I've not done this particular one, but my view is that a carefully operated hand tool (i.e. an ordinary hacksaw, once the bit that holds the bush is on the bench not on the car) will minimise the problem of totally f*****ing the alloy bit that the bush pushes into.
Power tools are great, but when cutting steel that's pressed into alloy.......
Cheers
JohnW
Stewart
Cheers
JohnW
No problem doing it on the car - keep the blade parallel to the sleeve and make sure you don't tip at the ends - then look at it when you're nearly through. Didn't even nick the alloy on mine!
I would have done it with a jig saw if I'd been able to get it in and would have reconed to be able to avoid the alloy with a bit of care.
jeremy
jeremy
