BX engine removal
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote">DLM - It's the red one, a TXD via EBay. The other isn't black, it's dark green TZD bought as a donor for the TXD. Shame it's a breaker as the body and trim is sound but its mechanicaly ****ged!<hr height="1" noshade id="quote"></blockquote id="quote"></font id="quote">
Mechanically ***ged it may be but I bet you can find plenty to pilfer from it!
I've got a decent 1900 engine (160k) with Lucas injection in a red TGD which rode nicely, but didn't have such a great shell. Thouch clutch and Rad are on the way out it could make a nice donor lump if you or anyone else is interested in the long term. Sounds like you're going to be rather busy for a while, though!
Can you imagine her reaction when I mentioned the 4x4 BX going for free earlier this week?[:0][B)]
It's a good job I don't have a large lump of land as it would very quickly fill with the darn things!
This is all Jon's fault, makes a big song and dance about his TZD, and we all dash out and do the same. The madness continues[:o)]
Before you get too hasty tossing other fans in, check this out;
http://www.andyspares.com/discussionfor ... C_ID=10752
That refers to a Xantia but I'm positive that the BX ones are ten times simpler. As a bonus, with new bearings etc, run at about twice the speed they seemed to before and are as quiet as a Churchmouse.
Alan S
Alan S
hello,i.m from romania and i have a bx 14 citroen . i want to now if somebody can help me with some advices about my car.i have a carbourateur problem. the car is running only when the shock is on. if i dont pull the shok all the car begin to trembele and the engine die.wih the shock i can go with the car but it take a lot of gas. please give me some advices.
ps.excuse my english
Hi Vlaicu -
I believe it is the idle cut-off electrovalve that does not activate when engine is running.
It is the only thing on the carburettor that has an electric wire.
Have the ignition on - do not start engine. Then remove the spade connector on this electrovalve. By touching the connector to the terminal, you should hear the valve clicking. Also some sparking should occur on the connector.
If it does not work, then try if you have +12V on the spade connector.
thanks, i already try that and the electrovalve is OK.can you give me some other causes that can make this efect?I have another friend who have also a BX14 with the same problem.thank's for your quik answer and i wish you a good week-end because mine is **** withaut car(I wanted to go fishing).
PS1:it coud be posible that the electovave is damage but to click and to have sparks
PS2:do you know other members of the forum how have BX14
