xantia abs
davethewheel
xantia abs
i've finally got round to sorting out my fault on the abs and have found the front nearside sensor is not working, i'm about to order a new one from gsf but have a question, when the ignition is turned on and the abs light comes on it flickers 3 times and then stays on, is this some kind of code saying there is another problem with the control unit or is this normal , i've had the bulb removed for about a year so i can't remember if it always did this. [:)]
Kowalski
This may be of help.
http://www.andyspares.com/discussionfor ... C_ID=10782
davethewheel
