<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by philhoward</i>
One of the best places to tap into is the feed to the fuel pressure regulator. A boost gauge will normally come with a t-piece which will fit into this pipe. Other end to boost gauge.
By the red arrow... http://homepage.ntlworld.com/phillip.ho ... engine.JPG
cheers for that (helps to see when not yet mechanically minded what the dickens I am looking for) but what is the thing that I have outlined and arrowed I have a blanked off cap there?
http://www.upimages.com/uploads/52f9c7cd5d.jpg
activa turbo
That's a dump valve (not standard); only needed if you go higher in boost terms. Not sure if the Activa engine has a recirculating dump valve as standard anyway (probably wont need it as its low boost anyway).
It was the first pic I found of an Activa engine on Google! Sods law it isn't a standard one...
- My Cars: Current:
Volvo V60 D4 180
Previous:
BX16RS (two of),
BX19TZI,
Xantia 2.0i saloon,
Xantia 2.0 Exclusive CT turbo Break,
Peugeot 807 2.0 HDi 110,
Renault Grand Scenic, 2.0 diesel (150bhp)
C5 X7 2.0 HDi 160 which put me off French cars possibly forever - x 16
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by PowerLee</i>
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by Homer</i>
I imagine if the turbo wasn't working it would perform like a N/A 8valve. Which has no go at all below 4000 rpm.
I have a N/A 2 litre 8 valve 405 & that pulls fine from 2500 RPM, It has plenty of go.
You havn't tried the Turbo version then. I've had both and I thought the N/A was reasonably flexible, but would have been better suited to a BX until I tried the TurboCT.
Don't forget the Xantia is a bit of a porker, and the Activa is about the heaviest Xantia (heavier than the same engined estate even). So it's probably not so bad in a 405.
