On a petrol turbo car, an intercooler allows more boost because the limit on boost is determined by how much pinking / detonation you can put up with. An intercooler allows the ignition to be advanced more.
On a diesel if you want more power, you need more airflow through the engine, the intercooler will be restrictive but making air denser should allow more to flow. The lower temperatures should increase efficiency too.
TD intercooler
Just a note,
I have used the standard zx td intercooler and front mounted it. Its more than capable as well.
With regard to the 'funny oval' connection that bolts to the standard manifold; If you have 2 of these intercoolers, you can change the oval end tank to another hose connection one by prising up the metal tabs. Its what I did and it held about 40psi or something in a bucket of water with no bubbles. Nice and cheap too.[:D]
