new diesel injectors
prm
My Cars:
Post by prm »
bxbodger
Got a few spares that may help. Ex 90, TZD at 130k. All working, for about the cost of a single recon injector.
Set of injectors, heaters, pump - Lucas 058 and complete heater relay assy.
Spares based at Walton-on-Thames Surrey.
R
bikeboyz
My Cars:
Contact:
Post by bikeboyz »
My 504 with Roto Diesel injection was really smokey, so LSUK overhalled them at £25 per injector plus VAT, you get the whole lot next day, with washers, and even a coat of paint!
bxbodger
My Cars:
Post by bxbodger »
Hello, PRM, thanks for the offer, but I have now ordered them up.
bxbodger
My Cars:
Post by bxbodger »
Update om this- I have finally got around to putting the recon injectors (nice weather, no overtime, and impending smoke test) in and what a difference it makes- there's now no visible smoke when its flat out on the governor uphill in third, and it sounds a lot more 'dieselly'.
The old injectors were recessed arond the tips, only by a fraction of a millimetre, with the needles sticking out by an equivelant amount.
The reason for resurrecting this post is to clear up the seal mystery.
I got them from the Pug dealers, after much screen searching, and they do for all XUD diesels, turbo or not, part numbers as follows:
<b>P0000198105</b> 15p each
<b>P0000198102</b> 8p each
Making a grand total including vat of £1.08!!!!!- Bob Smith, you were conned!!!
I dont know which numbers were the copper ones and which the crush ones- I could probably have got away with reusing the copper ones but not the crush ones.
Wookey
(Donor 2019)
My Cars: Peugeot Expert 1.9D (Camper conversion) (2003-now)
x 12
Contact:
Post by Wookey »
And my little addition to the above - The crush washers ('fire seals') aren't copper - I was wrong above. They are probably stainless steel. I got new ones of both when I had my injectors tested, but that was from a very sound shop where they throw that sort of thing in. As bxbodger says, they aren't expesnive, even from main dealers.
bxbodger
My Cars:
Post by bxbodger »
I was able to fish them out using a magnetized screwdriver so they arn't copper or aluminium, and the old ones wer'nt tarnished so, yes, stainless is probably the most likely!!
Kowalski
My Cars: Ex 05 C5 2.0 HDI Exclusive 145k
Ex 97 Xantia 1.9TD SX 144k
Ex 94 Xantia Dimension 1.9TD 199k
Post by Kowalski »
Good quality stainless steel is non-magnetic.
If they're stainless, they're not good quality.
bxbodger
My Cars:
Post by bxbodger »
Whatever they are, they are a genuine Peugeot part, probably the cheapest thing on the list!!!
Post Reply
