Use a metal one but make sure the head is skimmed, it faily cheap.
Make sure you fit the gasket dry "NO" gasket sealant, as long as you clean all the stud holes use new bolts and tighten them correctly you should not have ant trouble unless you cook the engine.
Old style paper gaskets are ok but PUG and Cit fitted the new metal laminate type on later XU td's and they are more robust suffering far less failures
Cheers
AX d 212,000 miles
XM td 295,000 miles
Diesel Power !!!!!
try turbo dynamics in dorset they no what they are doing www.turbodynamics.co.uk 01202487497
Hi Twiss, may be a good idea to upgrade your brakes? I put Volcane aircooled on my fronts, and while you're at it, get the Volcane velour interior and leather steering wheel. [^]
As for all the tuning you are doing, if I wanted a fast car to play with I would buy an old jag personaly, you can get one for peanuts... 5.3cc V12 FI are quite nippy [8)].. heh heh.. [:o)] [:D]
Just reading through this topic and have noticed several people recommending the NA diesel camshaft. I have look this up on both Citroen PR.net and my Peugeot parts discs, and both the NA and TD cam come up with the same part numbers on both sources, meaning they are the same part, so probably no gain from fitting one??
