WHATS A MAP SENSOR???
Just place a cheap petrol in line filter in the rubber hose to the MAP sensor if fitted this stops all oil fouling. For £1.20 from any motor factors it's worth fitting. If going to clean use brake cleaner as carb cleaner is too harsh. Leave on a radiator over night with a paper towle under neath it to drain any oil out as well.
Hi Richard,
What is it that I am looking for. All I can see is a plasic box affair under inlet manifold, and a plug with a white connector coming from it. It looks like a radiator fan switch thats on the BX, about the same size nut on it too. Is that it ??. Or is it in that box.
Thanks for your help
Greg
Greg
