Front BX seats could be swapped BETWEEN Citroen BX and Peugeot 405.
Can I replace ZX front seats by a Peugeot Model? Which model?
I found a Peugeot 306 3 doors but mounts where different.
Frank
Replacing ZX front seats ........
Dunno..
But when swopping the front seats on a ZX always undo the back bolts from the floor first, coz if the front plastic base comes undone on the front ones, you can't get the bolt out untill you get the seat out altogether, and cant slide the seat far enough foreword to get at the rear bolts either!.. Dohh.. [:I]
I once put Escort Ghia seats into a Fiesta, simply swap the seat mounts over.
Fiddly and may not work between brands (ie, dont expect a Volvo seat to fit a Citroen subframe) But the best way of ensuring a seat will fit into the car is to use the existing subframe & runners.
I cant see why a 306 seat could not be made to fit though. Dont expect the rear seats to fit.
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by martyhopkirk</i>
It may be 3 doors 306 have different mounts. I will search from scrapyard Peugeot 306 5 doors, and check her front seats.
No Other Peugeot models to swap ZX front seats?
