http://www.andyspares.com/discussionfor ... C_ID=11040
Following the conclusion of multi-level discussions with Significant Other, I'm the proud owner of a BX TZD. Yippee!! The £30 asking price might yet turn out to be the first bargain of the new year, or £30 down the drain.
Once the car is legal and safe, the plan is to offload the ZX, as there is no way I can afford or justify 2 cars. My line of reasoning was that as a car isn't necessary to earn a living, then we might as well have one that inspires a bit of pleasure in ownership. The ZX is a fast, cheap, nippy reliable motor, but dull... oh and the BX is red. It's obvious, innit?
Anyway, so far I've fitted new brake pads, tut-tutting over the vandalism of whoever cut the wear indicator cables, and have doubled the value of the car by filling it with £30 worth of Hydraflush. The power steering is gradually responding to the Hydraflush, so it may not need a new rack after all [:)] I'll let the garage sort out the wheel bearing and the welding, and have a crack at the gaiter myself.
It will need new tyres sooner rather than later, wheel balancing, various other procedures and remedies.
The interior trim is in OK condition, some ding-a-ling has tried to take the heater controls off with a screwdriver, leaving 3 big dinges in the dash. The driver's side window has a mind of its own and there are various lights etc missing. But on the whole it's a great project.
And it's red! Did I already mention that?
Well, I bought it : )
Sounds like a nice project!
Don't be too hasty to blame a previous owner for the brake wear leads, though - the car has a tendency to cut them itself when you're not looking[:D]
I've yet to find a way of routing them which completely avoids the problem, but if you do your own servicing the warning system isn't really necessary anyway.
Good man.
Please come along and register at www.bxclub.co.uk
We're here to help!
Ah, the BX from Bristol on Ebay thats made its way to Kent![;)]
Good luck.
We're here to help!
Good luck.
