yeah got a price for 25 quid
the ignition can i take that out of any peugeot 306 petrol/diesel. Cos im a bit confused cos some people said that the ignition set is everything with a key but i dont need all that do i?
Car not cranking
It does appear that you might have an ignition switch fuse in the engine compartment. I got this from a site:
http://www.peugeotlogic.com/fuses/fuses ... elist9.htm
306 Main Fuse Box (BF30)
Fuse
Rating
Supply
Function
F1
F2
7,5A
Ignition +ve
Automatic transmission ECU
F3
F4
5A
Ignition +ve
Passenger adirbag neutralisation, instrument panel, passenger compartment protection unit, coolant temp. unit, automatic transmission selector light, selector locking.
F5
25A
Ignition +ve
Stop lights, pressostat, ABS, AC compressor, left cooling fan.
F6
5A
Clock and autside temp. display, passenger compartment protection unit, instruments, boot light.
F7
30A
Rear screen heater.
F8
20A
Passenger compartment protection unit, radio.
F9
20A
Engine ECU, AC compressor, fan.
F10
20A
Hazard warning switch, front and rear interior lights.
F11
10A
Sidelamps+
Hazard switch – lighting switch, clock and temp. display, radio, ashtray light, headlamp height adjuster, lighting rheostat, front cigar lighter, heated rear screen, heated seat, AC control unit, transmission selector light.
F12
10A
Rear fog lights.
F13
30A
Battery+
Electric hood relay (power)
F14
30A
Battery+
Rear electric window , heated seats.
F15
20A
Battery+
Towbar
F16
30A
Battery+
Electric front windows, sun roof.
F17
20A
Battery+
Light switch
F18
10A
Front fog light
F19
10A
Sidelamps+
Right tail light.
F20
30A
Ignition ve+
AC blower motor, AC ECU, steper motor for mixer and inlet flap.
F21
10A
Sidelamps+
Headlights, left tail light, running lights or light switch.
F22
10A
Acc +ve
Heated rear screen, AC blower unit.
F23
20A
Acc +ve
Front cigar lighter
F23b
20A
Battery +ve
Front cigar lighter
F24
10A
Acc +ve
Radio
F24b
10A
Battery +ve
Radio
F25
10A
Acc +ve
Cabriolet, hood, central unit supply and switch.
F26
30A
Acc +ve
Front screen wipe and wash.
F27
15A
Acc +ve
Hazard signal switch, rain sensor, front and rear interior lights, map reading light, vanity mirror, passenger compartment air thermistor.
F28
15A
Acc +ve
Battery light, clock and autside temp. display, rear electric window, rear heated seat, electric front windows, sun roof, rear wiper.
Fusebox in engine bay. BH12
Fuses
Rating
Supply
Function
F29
10A
+ dipped beam
Left low beam.
F30
10A
+ dipped beam
Right low beam
F31
10A
+ main beam
Left high beam
F32
10A
+ main beam
Right high beam
F33
15A
+ inj. relay
Injection ECU (DW 10 engine)
F34
10A
+ inj. relay
Oxygen sensor
F35
15A
+ inj. relay
Fuel pump
F36
20A
Battery +
Headlight wash timer
F37
40A
Battery +
Cooling fan.
F38
F39
40A
Battery +
Spare fuse (fan unit)
F40
40A
Battery +
Cooling fan.
4 Fuse box in engine bay. BMF1
Fuse
Rating
Supply
Function
MF1
40A
Battery +
Ignition switch.
MF2
60A
Light and signalling switch, ventilation, heating and AC, front fog lights, diagnostic connector.
MF3
60A
ABS
MF4
60A
Supply for the fuse box in the passengers compartment.
Technical information by
Fuse
Rating
Supply
Function
F1
F2
7,5A
Ignition +ve
F3
F4
5A
Ignition +ve
F5
25A
Ignition +ve
F6
5A
F7
30A
Rear screen heater.
F8
20A
F9
20A
F10
20A
F11
10A
Sidelamps+
F12
10A
Rear fog lights.
F13
30A
Battery+
F14
30A
Battery+
F15
20A
Battery+
Towbar
F16
30A
Battery+
F17
20A
Battery+
Light switch
F18
10A
Front fog light
F19
10A
Sidelamps+
Right tail light.
F20
30A
Ignition ve+
F21
10A
Sidelamps+
F22
10A
Acc +ve
F23
20A
Acc +ve
Front cigar lighter
F23b
20A
Battery +ve
Front cigar lighter
F24
10A
Acc +ve
Radio
F24b
10A
Battery +ve
Radio
F25
10A
Acc +ve
F26
30A
Acc +ve
F27
15A
Acc +ve
F28
15A
Acc +ve
Fuses
Rating
Supply
Function
F29
10A
+ dipped beam
Left low beam.
F30
10A
+ dipped beam
Right low beam
F31
10A
+ main beam
Left high beam
F32
10A
+ main beam
Right high beam
F33
15A
+ inj. relay
F34
10A
+ inj. relay
Oxygen sensor
F35
15A
+ inj. relay
Fuel pump
F36
20A
Battery +
F37
40A
Battery +
Cooling fan.
F38
F39
40A
Battery +
F40
40A
Battery +
Cooling fan.
Fuse
Rating
Supply
Function
MF1
40A
Battery +
Ignition switch.
MF2
60A
MF3
60A
ABS
MF4
60A
Alright
This is weird. I did what you told me by connecting two wires but we actutally used jumpers. So we connected the jumper from the starter motor where the two wires are and the other end on the positive side of the battery. It sparked and the car tried to turn but didnt. Making a noise like something was stuck when turning ignition. So we push started it and drove for a while. Then turned car off turned it on again and it started fine. Started it this morning and it was ok. Got a battery check done and the guy said that the battery is dying. On his meter i think it read 13.72 or something whatever that means
what could it have been? just the battery?
Sounds like solenoid or, more likely, starter was stuck. You probably freed it by making direct connection. If the meter was showing 13.72 volts that is not bad! Did he do a complete check including specific gravity? Keep the battery for a wee bit before splashing out on a new one. If it is down in the morning go for it. If the starter problem recurrs with a new battery go for a scrap unit. Glad you are mobile again.
I ended up buying a new battery last night. The battery i did have in there was 44 amps not ideal for a diesel but i have been using it for 3 years or so. Started this morning and it was fine no jutter or anything. Hopefully thi should have fixed it. If it happens again its got to defintely be a starter motor am i right and not an ignition switch cos it must have been that the starter motor was stuck like you said?
