how do you start a diesel with no glow plugs???
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by NiSk</i>
Beezer and Nick - I've still got a 1952 Ferguson TE20 petrol/TVO (Tractor Vapourizing Oil = paraffin). It runs OK on petrol but isn't very powerful on paraffin, whats more, paraffin costs more than petrol over hear so the whole thing is just for the sentiment of it!
Dunno about Sweden, but in the UK it is usual to run old petrol/paraffin tractors on domestic heating oil. Certainly the father's David Brown Cropmaster runs on it without protest...
I know one filling station here that sold paraffin for £1.10 per gallon until recently. The diesel Fordson actually runs well on paraffin too, better than it runs on derv. It will also run quite happily on used LHM fluid [:D]
Its surprising how easy it is to get parts for old tractors, just a case of knowing where to go and who to ask.
- uhn113x
- My Cars: 1981 Dyane - on road all year round.
1982 GSA Pallas - on road April - September.
1997 ZX 1.9D Dimension. - x 1
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by beezer</i>
In my truck driving days of the early seventies we didn't have glow plugs (eeh by gum etc). The Ford trucks had a 'cold start' lever which was accessed through the radiator grill and needed a second person to operate it. <hr height="1" noshade id="quote"></blockquote id="quote"></font id="quote">
That is because they were direct injection engines. The cold start device simply allowed the fuel rack to move beyond the normal full fuel position.
Glowplugs are only of use in an indirect injection engine where the fuel is squirted into a swirl chamber.
It then became illegal to make a vehicle where it could be operated from inside the cab (for extra climbing power!) so the device became a button on the injector pump or a thing poking through the grille.
Modern car direct injection engines mostly use glow plugs. As far as I know glow plugs were invented for indirect injection engines which were not as efficient as direct ones. Glow plugs reduce cold start emissions so are retained in compact car direct injection engines. The beasts that ran our trucks were noisy and smelly. The bosses had huge bedsprings fitted to the throttle linkage to keep our speed down. Everyone used to take them off when they left the depot and replace with weaker ones. Much easier on the right foot when you are using it all day. I don't know when glow plugs appeared on Transits. We had Bedford CFs without them and the first glow plug Transits we had were bought around 1975.
- Contact:
Everything in an autobox is controlled by hydraulic pressure - built up from a pump driven by the torque converter - so its difficult to imaging how one could create a situation where the correct oil pressure could be built up by towing. In fact many autoboxes demand that they are not towed more than a short distance and at a low maximum speed, since they have no lubrication when not being driven by the engine.
//NiSk
//NiSk
The 3 litre had a fluid torque converter but it was even in the handbook that it could be started at 32mph. Strange.....
This link might explain (slightly):http://vets.list.archives.mbz.org/1999/ ... 1_Num_877/
