No Second Gear!!!!!!!!!!!
Just wondering if anybody had an idea my car is a citroen ax 1.5 diesel tud5 and its covered about 60k miles. after finding out that the head gasket is seeping the dreaded oil everywhere. now when drivin i can't get the second gear all the rest work perfectly, this is my 1st car. Help and please tell me not all citroens are this bad! lol
Not all Citroens are that bad, mine are usually ,much worse.
Now to stick my neck out here, is your head gasket leaking oil out of the head or into the water? If its just out of the head, ignore it, my visa xud engine did that for thousands of miles no problem. No second gear, could you elaborate? Is it just nothing when you engage it? cant engage it? tried a bit of double de-clutching and sneaking up on it? WOrse case scenario a used box isnt that big a deal on an ax.
Hey guys, as your on the topic of gearboxes, i was wondering if changing from a 4 speed box to a 5 speed is just a simple swap? I have a '93 ax debut (1 litre) and use it on the motorway often wanting to change into 5th to stop her screaming!
obviously Im thinking different models have various ratios so which would be most suited to the 1litre. Did citroen ever offer a 5 speed for this engine? I know my friend's saxo has 5 gears, im sooo jealous!
