Creaking as she lowers...
My xantia sometimes creaks loudly when it the height is settling after first starting the car. It happens when the car lowers itself. It will do it even if the car has only been standing for a couple of hours. Is it normal? Anything I should check?
I sometimes get a cracking noise from the front discs as they first move - if I've come home with them cold and wet, then left the car a day or two, then I assume that the pads rust to them and you get a great creak/crack as the "joint" is broken. This may not be relevant, it just flashed into my mind when you said "releasing the handbrake...".
Pete
Pete
