Xantia - demister
Post Reply
Gavin1
My Cars:
Xantia - demister
Post by Gavin1 »
I have a Xantia Td M-PLate (no aircon) Whenever I park under a tree the air vent blow out the seeds, bits of leaves through the dashboard air vents. Is there a filter of any sort? If so where is?
Cheers Gavin
Jon
Post by Jon »
Guru Dave Burns will probably correct me<img src=icon_smile_wink.gif border=0 align=middle> , but I seem to recall that only Xantias with Aircon have a pollen filter, with is located under the dash on the passenger side.
If the car does not have aircon, then it gets its cold air feed from the scuttle area under the bonnet. There should be a plastic mesh that should stop leaves etc entering the fresh air system.
Jon Wood
IT Supervisor
GSF t/as Andyspares
Post Reply
