Notes on ZX TD Valve Shims
- My Cars:
In case anyone else rebuilds their ZX TD engine and needs to buy new valve shims you may like to know that when specifying the shim thickness you should calculate to the nearest 0.025 mm. If you know this before hand it saves have to work out in the shop (like I had to) which is the nearest thickness to the one you require.
