AX battery problems
Post Reply
GrahamHick
My Cars:
AX battery problems
Post by GrahamHick »
Couple of AX questions:
1. What type of nut is required to hold down
the clamp which holds the battery in place.
2. In the last few years I have replaced the battery 3-4 times. Generally a bettery only lasts around a year. What things should I look for to find out what's wrong?
alan s
RIP 2010
My Cars:
x 6
Post by alan s »
Graham,
I would suggest you either have an auto electrician look at the charging system or alternatively put a meter on the car to check on the charge rate. It should charge at 13.8 to 14.6 volts from memory, & I would suspect that yours would be in excess of that. Probable cause a dodgy voltage regulator. My guess is that you're cooking your batteries. I don't know if they are adjustable, very few are these days, normally they are solid state & not overly expensive.
Post Reply
