Hi all,
Can anyone tell me where I can find the sensors for the Engine Temp gauge, Speedo, and Rev counter.
many thanks
Xantia - various sensors
- My Cars:
- My Cars:
Hi Ian, temp gauge sensor is on the thermostat housing, can be either on the left or right front corner of it dependant on wether or not aircon is fitted, if no aircon sender is on the right, should be blue connector.
Rev counter (TDC) sensor is in the bell housing flange on the block, sensor faces the flywheel, later models have a lift sensor on one of the injectors.
Speedo transducer or cable, right hand side of diff housing as John says.
Good luck
Dave
Good luck
Dave
- My Cars:
- My Cars:
OK, I've found the speedo and rev counter sensors - no probs there.
As for the Temp Gauge, I have 2 things on the thermo housing, one left, one right and they're both blue. The left one has 2 wires, the right one has one. I don't have aircon.
If it helps, it's a 94 1.9TD hatch.
On another note, is there any easy access points through the bulk head? I need to run a 4awg cable from the battery to the boot.
Once again, many thanks for the help.
Ian
Ian
- My Cars:
- My Cars: 2010 Citroen C5-X7 tourer
1998 Citroen Saxo 1.5D
2018 Citroen C4-B7
1998 Peugeot 306. 1.9D
2011 Citroen C1 - x 72
- Contact:
If your Xantia is anything like my '98 version, there is a plastic cover running the length of the car on the o/s. I ran several cables from a fuse box near to the battery down to various relays in the estate/boot for caravan fridge and battery. I put three wires inside a plastic tube then put it all under the plastic cover. The wires enter the boot through a grommit in the floor.
- My Cars:
- My Cars:
- My Cars:
- My Cars:
