flashing stop light and temp light
Post your Cit/Peu/Ren air conditioning queries or advice.
Post Reply
KennyW
My Cars: Current Citroen's
C5 x7 2010
SWMBO C3 2012
Previous Citroen's
Xantia 2.0 90hp estate
Xantia 1.9 TD estate
x 132
Post by KennyW »
Hi All,
Got the abovelights flashing on dash. Citrojim suggests a problem possibly with connectors , sensors etc.
Can I confirm the double fans are a similar set up to 1.9TD but what are the differences.
How do I set both fans spinning ie brwon sensor on 1.9TD pulled will cause both fans to spin at full speed.
Kenny
C5 x7 2.0 HDi 160 hp Estate exclusive, the newbie
C3 1.4 petrol (SWMBO)
harryp
(Donor 2022)
My Cars: Forte HDI 110 hatch in wicked red, SORN
Exclusive HDI hatch in quartz, SORN
C4 Picasso Exc E, Wifes
Peugeot 207cc
x 73
Re: flashing stop light and temp light
Post by harryp »
Similar symptoms can be caused by faulty fan relay when aircon on via switch or demist. IIRC, center relay base corroded on mine. Relays in triangular box in front of fan housing. HTH.
Regards, Harry
2000 Nov Forte HDI 110 hatch in Wicked Red; currently SORN
2000 Mar Exclusive HDI hatch in Quartz; currently SORN
2013 C4 Picasso Excl E
Peugeot 207cc 1.6 Roland Garros
citroenxm
My Cars: M reg Xm S2 2.1td Auto Exclusive. 269k and rising
L reg XM S1 V6 12v Manual SEi
L 94 XM 2.1 TD auto total resto
2008 Peugeot 207 Sw 1.6 16v hdi. 217k and rising
2010 Peugeot 207 SW 1.6 8v HDi 161k and rising
x 71
Post by citroenxm »
As Harry has written, first area to look in the triangular box between the Fans, the flashing of the Temp light indicates the SLOW SPEED is not working....
A very sad...
1994 XM 2.1 d auto
KennyW
C5 x7 2010
SWMBO C3 2012
Previous Citroen's
x 132
Post by KennyW »
Thanks for the replies,
I have a full set of relays from TD which I think will be the same.
IIRC when I started her up it was the right hand fan that came on immediately which did raise an eyebrow.
Just to confirm right hand fan is driver's side look at car from the front.
Kenny
citroenxm
x 71
Post by citroenxm »
Yes.. left and right is referred to as though you are sitting IN the car..
A very sad...
1994 XM 2.1 d auto
KennyW
C5 x7 2010
SWMBO C3 2012
Previous Citroen's
x 132
Post by KennyW »
Well, took off relay cover between fans and right hand relay, it has shorted across pins 4 and 5 which has melted down the relay between them.
Will need to replace relay holder and check wiring.
Interestingly, the relay is a 5 pin but on wiring diagram it is 4 pin.I've 2 4pin relays spare which are new from TD. Also I see the secondary supply for hhigh speed mode is run throught the double injection relay.
Kenny
citroenxm
x 71
Post by citroenxm »
Good luck changing the house Kenny, wiring behind the relays is increadably TIGHT and the holders hardly come out forward to work on them...
A very sad...
1994 XM 2.1 d auto
KennyW
C5 x7 2010
SWMBO C3 2012
Previous Citroen's
x 132
Post by KennyW »
Yeah, Paul I remember the fun I had with my TD.
I was think of removing radiator and fans to improve the access if required.
But I'm going to try and check the base is okay first.
Kenny
citroenxm
x 71
Post by citroenxm »
If needs get desperate.. im sure theres a couple of spare fan units here kenny...
A very sad...
1994 XM 2.1 d auto
KennyW
C5 x7 2010
SWMBO C3 2012
Previous Citroen's
x 132
Post by KennyW »
Thanks Paul will bear it in mind.
KennyW
C5 x7 2010
SWMBO C3 2012
Previous Citroen's
x 132
Post by KennyW »
Hi All,
Well put 4 pin relay in and the fans are working. Left fan a bit sticky will require some lubrication.
Post Reply
