help needed my xantia td 1993 L reg
its had a new rear h/corrector
new lhm and hydraflushed and new lhm filters (yes new not cleaned)
also a new accumulator sphere
the back still 3 times out of 4 goes all the way up 'rock hard'
the front is at correct 'normal' ride height
when it rides correctly it is smooth as silk
the lever inside car is a bit (but not much) stiffer to move than my old bx (perhaps needs to be cleaned and lubed)
is it something as simple as setting up ride height on rear ( i just left clamp where it was snapped on the link rod)
or could it be the linkages front to back that connect to lever inside of car sticking
or is the h/p pump faulty?
it does the normal(?!!) dip at back when brake pedal pressed, goes up when released. the front also creeps up in stages like they do when struts need doing
i just want to sort height before i sort struts unless this is connected.i can drive it with the front struts but not with the back up!! it shakes your teeth out (i actually dont drive it like that before anyone comments - i settle it with the cit up and down dance!!)
anyone know the cure to its hotrod act???? PLEASE!!
G J Wright
xantia height help
- ukmobileman
- My Cars:
- Contact:
- My Cars:
- ukmobileman
- My Cars:
- Contact:
i did quickly wire brush and lube (wd40 and saltwater spray gease) the pivot near h/corrector when i fitted h/corrector but to be honest i didnt strip it down or anything as i thought it was h/corrector at fault .
is there more than one pivot in linkage rods as the inside lever feels a lot stiffer than old bx. i guess i will have to get under a trace rod linkage and clean and lubricate them properly.( i use axel stands/ramps)
G J Wright
G J Wright
- My Cars:
- My Cars:
Been a car maintenance day today, changed the oil and filters and finally cured the airbag fault, cut connectors out and soldered wires together under the front seat's.
Also went under and adjusted the rear ride height, there are infact two pivots to the mechanism, one which was well worn and was partly the cause of the low height, the other was a bit on the stiff side but was still working ok.
A well worn plastic link contributed to the rest of the play in the linkage.
The pivot's can't be dismantled because they are riveted to the bracket.
Dave
Dave
Fitted a new rear height corrector recently & had same problem.
Spoke to a mate (Cit fitter) Advised to check rear ride height.
Simple guide, centre of hub should be between 13.5 & 14 inches from wheel arch in a vertical line, when in normal drive position.make sure all pivots & links are well lubed. According to andy spares, all new ride height correctors will need height resetting on fitting
Jon
Jon
