all the brakes on the ax are locking on, its not the master cylinder or the calipers, any ideas? Common problem?
thanks
misterroy
ax brakes jamming on
- My Cars:
My wife has an AX that had the same problem.
It was caused by dirt fouling the rod that goes across the bulkhead from the back of the pedal to the servo.
It can be cleaned by passing a welding rod (or other piece of stiff wire) with a piece wool or string attached to one end through the sleeve with the rod inside and use the wool like floss to clean it out.
Hope this helps
Ally
Hope this helps
Ally
