Replacing Xantia Harisson compressor
Post your Cit/Peu/Ren air conditioning queries or advice.
Post Reply
lazza
My Cars:
Post by lazza »
Hi Forum
I'm about to change the aircon compressor on my Citroen Xantia. I seem to remember hearing that i should change the dryer at the same time??
My general question is: What should I change aswell as the compressor?
Thanks very much
Larry
(1996 Citroen Xantia 1.9TD LX with aircon)
Living in exile in Spain
Running on 100% veggie in summer
vanny
My Cars:
Contact:
Post by vanny »
Why are you changing the compressor and what are you changing it for (new, old, recon?).
You will likely need to add oil to the system.
It might be worth flushing out the pipes if the system is contaminated.
lazza
My Cars:
Post by lazza »
HI thanks for your reply
when you say add oil to the system.. do you mean i need to directly put oil in the compressor??
i thought that when they refill the system with gas, that they automatically put in a percentage of oil.
can anyone enlighten me?
thanks
Larry
Lexia Available: Yes
My Cars: -
1997 Citroen Xantia V6 (France)
1999 Citroen XM V6 ES9 (France)
2011 Peugeot 308 CC THP 155 (NZ)
1975 Jaguar XJ-S pre-HE (NZ)
x 835
Post by xantia_v6 »
The oil in an A/C system is in one of 3 states:
a) dissolved in liquid refridgerant
b) being blown along by gaseous refidgerent
c) sitting in the sump of the compressor
The oil in the compressor sump acts as a reservoir.
If an A/C system looses gas over a period of several years due to porosity, or the compressor shaft seal, very little oil is lost, so a standard re-gas does not include any oil. If any component is replaced, a new component is supplied dry, so an amount of oil corresponding to the residue in the removed component is added.
If there is a large leak that causes oil loss, the operator just has to guess how much oil to add (and sometimes what sort!).
If a used compressor is fitted, it is also a guess as to how much oil is in it (some have a drain plug, but even that seldom allows all the oil out).
In situations like this you need luck, or an experienced operator to guess the amount of oil to add.
lazza
My Cars:
Post by lazza »
Thanks very much for your reply
I am replacing it with a 2nd hand compressor- which I presume still has oil in. To be on the safe side:
How much oil should I add?
How and where do I add it?
Many thanks
Larry
MikeT
My Cars: 2005 C5restyle 1.6HDI 16v 110hp VTR Estate
2008 C5 X7 1.6HDI VTR+ Saloon
x 232
Post by MikeT »
Hi Larry,
Sorry I can't be of more help as I have little to no experience of A/C systems other than common knowledge.
What I can say is that compressor came from a filled system (on removal I accidentally punctured the condensor and the gas leaked out) and in my care, have not noticed any oil seepage from the compressor so, hopefully, there's still the right amount in it.
Post Reply
