Sphere Removal Tool
Forum rules
Please do not include personal contact details (addresses or phone numbers) in your posts or they will be removed. Please use the Private Messaging system to ask for or to provide this information.
- myglaren
- My Cars: Mazda 6
Ooops.
Previously:
2009 Honda Civic :(
C5, C5, Xantia, BX, GS, Visa.
R4, R11TXE, R14, R30TX - x 4922
Sphere Removal Tool
Not me selling!
I spotted this thread on Autoshite a couple of days ago and thought it may be of interest here.
Have gained permission from the thread starter and the PWB at Autoshite.
Thread is here:
http://autoshite.com/topic/24377-excell ... ntry985845
It may look a bit strange compared with others but appears to be quite a decent piece of kit.
Thread is here:
- white exec
- CitroJim
- x 6204
- Contact:
Re: Sphere Removal Tool
Interesting. I see two issues, very hard to apply 'percussion' to assist in loosening a very tight one and it may struggle due to space issues to crack off the Xantia front Hydractive and rear Activa spheres...
There's an official Citroen tool that works on much the same principle but is more like a tightening band and works a bit like a piston ring compressor - it has the big advantage of being very compact but again lacks any way to apply percussion from a 4lb club hammer...
For me the old faithful Pleiades tool still reigns supreme...
- myglaren
- My Cars: Mazda 6
Ooops.
Previously:
2009 Honda Civic :(
It is getting hold of a Pleiades one now though.
OP has just updated the autoshite thread.
Ebay seller has been most helpful and replied to my query.
No website.
Address is : Outillage Dams, St Daimas de Tende, 22 avenue Martyrs de la Resistance, 06430, Tende, Alps Maritimes.
Phone is 04 93 04 60 44 or fax 04 93 04 62 72.
He said it was around 90 euros new.
That Wanoda one above looks identical apart from the different markings on the cam.
- CitroJim
- x 6204
- Contact:
Yes, that's true Steve. I believe there's been no production for several years now and second-hand ones find a very ready market...myglaren wrote:It is getting hold of a Pleiades one now though.
- white exec
Easy enough to make up your own Pleiades-type tool: just a bit of steel strip bending, a weld or two, and a threaded hole.
- CitroJim
- x 6204
- Contact:
white exec wrote:Easy enough to make up your own Pleiades-type tool: just a bit of steel strip bending, a weld or two, and a threaded hole.
Absolutely! I'm rather surprised nobody has offered a direct copy of the Pleiades tool for sale - unless Martin has a strictly enforced patent/copyright on it...
The nearest is that one with the bolt through the ring that's not nearly so effective and lacks the critically angled handle...
I recently bought a track rod removal tool which is more or less a smaller version of that sphere remover. It works OK, but is harder to use than you might imagine. The ring has to be supported in place while the cam is 'wound up'. If it slips, you have to start again. One of those jobs requiring three hands on thin telescopic arms!
I have a DIY sphere tool in the fashion of a chain-type oil filter wrench, but it is made of a 3/4" socket and motorcycle chain
- white exec
These are my two, both home-made...
Top one inspired by Pleiades.
The Iron Maiden was made to fit round the Acc sphere in a very snug XM engine compartment, in conjunction with a large socket.
- Donor 2023
- My Cars: '00 Xantia 110 bhp Hdi SX Estate 65K "W"
'99 Xantia 110 bhp Hdi SX Estate 310K SORN "V"
'98 Xantia 1.9TD SX Estate 150K Sold "T" - x 47
Found this on ebay
http://www.ebay.co.uk/itm/like/11212904 ... noapp=true
Tesla Model 3 LR DM AWD Blue White
'00 Xant 110HdiSX Est 83K "W"
'99 Xant 110HdiSX Est 320K "V"
'98 Xant 1.9TDSX Est 150K "T"
'97 Xant 1.9TD 20k Est
'94 Fiat TipoTd 40K
'85 BMW K100RT 330K Garaged 26yrs '80 Honda CB250 twin Superdream
'94 Fiat TipoTd 40K
- My Cars: Currently:
In the past: 3, CX td Safaris and about 7, XM td estates. Lovely cars. - x 1207
I have one of those from ebay, worked very well and you could apply some some percussion, don't have a C5 now though.
Yep I've had two of those ebay ones. One from 2012 and another I bought in 2014.
The newer version of that actually has a bolt on both sides of the handle (shorter bolts than before) as well as extra bracing between the handle and the ring. The ring does still deform a bit when you tighten the bolt really tight (and needs straightening again to fit over the next sphere!) and you can't always make use of both bolts due to obstructions on the car, but for £15 it certainly does the job and is eminently hammerable with a block hammer, which is almost a requirement with some spheres to shock them free!
With some of the sphere's I've done battle with I'm highly dubious that the autoshite one would do the job on difficult spheres, especially when it wouldn't stay locked firmly on the sphere to allow hammering.
Simon
1977 G Special 1129cc LHD
1978 CX 2400
1997 Xantia S1 2.0i Auto VSX
1978 CX 2400
- NewcastleFalcon
- x 6890
Bargain Basement Sphere Removal Tool circa £1.50
Piece of threaded rod, couple of nuts and washers, axle stand, breaker bar.
I can't see that removing a front Hydractive sphere on a Xantia. Far too "fat" to clear the numerous nearby obstacles.NewcastleFalcon wrote:Bargain Basement Sphere Removal Tool circa £1.50
Simon
1978 CX 2400
1978 CX 2400
