Espace Towbar
Espace Towbar
Anyone ever fitted a Towbar to an Espace.Is it a difficult job to fit oneself.
- My Cars: 2010 Citroen C5-X7 tourer
1998 Citroen Saxo 1.5D
2018 Citroen C4-B7
1998 Peugeot 306. 1.9D
2011 Citroen C1 - x 72
- Contact:
No! I've never fitted a bar to an Espace, but I have fitted one to a Xantia, a BX, plus several previous vehicles. Every time, I've used the bars supplied by Towsure. The kits come with comprehensive fitting instructions, and providing you have, and can handle a set of spanners and a socket set, you shouldn't have any difficulty. Even the electrical connections are reasonably straightforward.
fitting a towbar is easy four bolts in total and the holes are already drilled for you,, the eletrics are a little difficult you need to route them into the left hand side (facing the car back end to front end) and connect the wires in the side storage box follow your wiring diagram and all should be fine good luck [:D]
