Has anyone come across a problem when engine is cold ?
The car always starts and ticks over, but if you pull away before the engine is a little warm there is no power and the engine hunts as if ignition problem. Already replaced the water temp sensor and air flow sensor, and garage has "programmed" ECU to no avail. Also when engine very hot if it stalls, the engine will not restart for 10 minutes!!!
Espace 2.0i No power on cold startup
