I've just purchased a 1999 'V' 306 1.8 XS, the electric oil guage confused me slightly, it read low, so i thought I'd add a litre it then rose to full? Could someone tell me the ratios on the gauge?
Cheers
EZ
Oil Levels
- My Cars: Current - Slightly modified 2016 Pug 308 Puretech 130 Allure
Past:
2003 - 206 GLX TU3JP & 206 SE ET3JP4
1995 - 405 Executive XU10J2
1996 - 406 GLX XU10J4R
1994 - 405 GTX XU10J2 - x 1
Hi
Does your local Peugeot dealership have an Express fit section???
They have been doing oil and filter changes for a tenner for the last few years.
You need to drain the level to the max mark on the dipstick, and seeing as you are draining some out, you might aswell change the oil and filter.
You will ruin the seals in the engine running with to much oil in it.
Past:
Im not sure what grade you should be using, But if you pop down the parts dept of your local Peugeot dealer you will find that oil & oil filters can be picked up cheaper then Halfrauds could ever dream off.
Brake pads are cheaper from the dealer also, In fact the main dealers service parts are all cheap [:)]
