I've got a 94 xu10j4 engined 405 (2l 16v). having just had the engine out and rebuilt it, it's all back together and turns over fine but will not fire.
No spark whatsoever and from what I can feel the injectors aren't firing either.
Don't suppose anyone has a wiring diagram????
does the diagnostic light on the dash come on at all during normal use? What I mean is does it come on when you first turn the ignition on and then go out once the engine is running?
Making matters worse is the fact that the car has 2 alarms. factory one which has been reconnected and an added toad one which for whatever reason has now been half disconnected. also the factory keypad type immobiliser has been bypassed in some way.
Might sound like a silly question but is there anything on the passenger side in the dash that buzzes??
When you turn the ignition on the fuel pump kicks in and then theres a faint buzz from inside the dash, at the same time as the buzz starts the light on the dash comes on.
Help!!!!!! 405 wiring
