Resently mine has been showing signs of the rack failing, ie lumpy steering. This turned out to be the UJ at the bottom of the rack about to sieze. After liberal amounts of copper grease this has solved the problem.
So anyone with 306 with heavy steering, greasing this joint could aleviate the problem and save this joint. as with all peugeots they are a t*"t to replace!!!
Kevin
306 tds heavy steering
