i have a 405 estate (mreg) and the rear left passenger door is jammed.
I cant get it to unlock using either the central locking or the internal door button. I can hear the central locking mechanism "working" when i try to use that but nothing happens. The front 2 doors unlock from the central locking. The rear right passenger door doesnt work off the central locking but thats cause either the unit is duff in that door or a wire is loose(im working on it slowly), but works fine off the door button.
so any ideas on how to get it open short of ripping it off violently?? i need to sort it soon cos the mot is due next month.
cheers in advance si
405 door jammed
I fixed the same problem on my car yesterday! I removed the door button, got some pliers on the rod inside and pulled it up. The button was just sliding on the rod and not pulling it. Having got the door open, I removed the trim and outside door handle, squirted some WD40 on the hinge where the rod meets the door lock. I think you can remove the trim without opening the door ??? My problem is the door button is knackered and won't grip the rod, but the central locking now works.
The door button can be removed by pulling it up then out. The window winder just levers off. You can use a small screwdriver to help release it so you don't to apply so much force.
You can get a new clip which fits inside the door button if it won't grip the metal rod for 36p. I'm getting mine on Saturday.
Come back if you need more detail
Matt
Matt
I think i didnt make my problem clear, the door button goes up and down when i use the central locking. ive taken the button off and checked the rod and tried already to open it using that. (was the only way i could get the other door open so was 1st thing i tried).
the central locking seems to operate in this jammed door ie the button goes up and i can hear the motor clicking when operated but the door fails to open if using either of the handles.
Aas to taking off the door trim im not sure if it can be done with the door shut because of the screws holding the speaker in to the door are only just visable but i'll find out later when i have a go at this door.
I took my other back door apart the other day to grease it up because its not working so i know how the door locks/central locking all link together and work. i thought id tackle the easy one first.
where can i get those little clips from?? i need 2 get a few and some buttons i was less then careful taking them off.
yeah the rod moves fine i can hear it click into place when it goes up and down.
But this evening i got the door to open up as normal. Just got back from a couple of hrs driving, with the heating cranked all the way (well it was bloody cold outside and snowing). And low and behold the door opened!!!!!!(no idea why i opened the door i meant to open the front one) i grabbed my wd40 as quick as i could and soaked the lock so atleast i know its now lubricated. Only thing is i shut the door and now its jammed again. stupid door.
Atleast i know it can be opened just got to work out how to fix it cos 2hrs with full heating in the snow is a lot to ask just to open a door...
cheers si
cheers si
