Rear Clusters
Post Reply
cheesesliceking
Rear Clusters
Post by cheesesliceking »
Hello people!
Can anyone please tell me what i need to do to make a pair of rear clusters from a 205 (K reg)fit onto a 205 (H Reg) or if indeed this can be done, i have a set but the drivers side cluster has two plugs going into it on the H reg & the K Reg has only one plug hole!!
Any help would be great.
Cheers
cheesesliceking
*BUMP*
jackherer
Lexia Available: Yes
My Cars: 205 GTI Mi16
208 GTI Prestige
C4 VTS 180
Contact:
Post by jackherer »
you need the plugs and at least a short bit of wiring from the k reg 205 to splice into the older cars loom.
I prefer to use the whole length of wiring from the late spec car (runs from the light clusters to the fuse box under the carpet) because then it all just plugs in as peugeot intended.
instructions for splicing are at http://www.205gti.com/techrearlightUK.htm
everything you need to know about 205s is at http://forum.205gtidrivers.com/
cheesesliceking
Cheers Buddy! i knew i should have taken the loom...DOH!
Post Reply
