307 anti pollution error faults 1.4 hdi
Post Reply
avamotor
(Donor 2022)
My Cars: 307 1.4HD
206
Citroen Xantia 1.9 TD
Post by avamotor »
Please can anyone advise me on what to look for with regards to rectifying 3 error codes found on Planet Peugeot 2000, codes as per below:-
Permanent fault, diesel pressure signal, short circuit to positive or circuit open
ECU fault code P1614
Engine speed 0 rpm
Battery voltage 11 volts
Coolant temperature 13 deg. C
ECU internal data 00
Engine status starting
Mileage 613 km
Permanent fault, intake air temperature signal short circuit to positive or circuit open
ECU fault code P0113
Engine speed 738 rpm
Air temperature signal 4960 mV
Coolant temperature 24 deg. C
Air flow sensor signal 0 mV
Engine status Engine operating
Mileage 613 km
Permanent fault, Rail pressure sensor supply supply outside tolerance
ECU fault code P0193
Engine speed 674 rpm
Rail pressure signal 4960 mV
Rail pressure reference value 337 bar(s)
Output injected 17 mg/impulse
Mileage 613km
Has anyone experienced the same code and how did you rectify it/them. The only thing i did note was there alot of bubbles running through the "clear plastic pipe" today so i guess that somewhere on collection of fuel pipes, it must be sucking in air but would welcome replys from anyone who knows what this could mean or has had similar error messages and codes.
Garry
BX
My Cars:
x 17
Re: 307 anti pollution error faults 1.4 hdi
Post by BX »
The first thing to check is the voltage and the earth to the mass airflow sensor and to the fuel rail pressure sensor. It sounds to me like a faulty earth.
Gibbo_Wirral
My Cars: Peugeot 206 Sport 2L HDI
Contact:
Post by Gibbo_Wirral »
That battery voltage of 11v would concern me. Is this after repeated starting?
Peugeot Planet Diagnostics: Wirral, Merseyside, Lancashire, Cheshire, North Wales
Post Reply
