I have got my new solid crank pulley now ready to change. I got all the arch covers out of the way.
I know on the altanator belt you loosen the black pulley tightness of the belt slack held in place to remove it.
Put the car in 5th gear and hold down the brakes to. When putting the crank pulley back in a line up and use thread seal on the bolt.
I'm using the same belt as its like new only changed a while ago. So can I just put everything back on and let the slack go tight back on the belt and thats it?
I read on if a different belt being used you need to a just the metal pulley. But I'm not changing the belt putting the same one back on?
306 hdi
Changing crank pulley
- Welshy_Pete
- My Cars: 306 hdi 1999 + 306 hdi 2000
