1.9 gti 205
stuart1
1.9 gti 205
Post by stuart1 » 22 Nov 2001, 22:08
has anyone had trouble with oil consumption increasing at 80,000 miles,and does anyone know where to get pistons and liners cheap just incase its not valve oilseals?
ps peugeot state 1 litre for 1200 miles is ok
mine used half that till last month now its using 1 litre for 1200 miles (far to much in my opinion)any suggestions welcome
reguards stuart
ps recent compression test revealed 150+ for cylinders
Edited by - stuart1 on 02 Dec 2001 11:52:22
KRISKARRERA
Post by KRISKARRERA » 01 Dec 2001, 04:02
What viscosity of oil are you using?
Some synthetics are great but very thin so it's more likely to seep all over the place through wee gaps.
But who knows? I'm no expert on all this.
How is the car performing?
If it's performing as good as it ever has don't worry.
Kris
jacksonr
Post by jacksonr » 02 Dec 2001, 01:17
I'm not sure what to suggest other than checking whether it's being burnt or leaking, check fumes on start up. I disagree that it may not be a problem if the performance is still there. If a seal has gone/is going, then it can perish quite quickly once it starts to degrade. Either way it would be a good idea to have it checked out, especially running it at this time of year.
KRISKARRERA
Post by KRISKARRERA » 03 Dec 2001, 03:27
ok smart-arse, well I said I wasn't an expert didn't I?!!!!!!!!!!!!<img src=icon_smile_evil.gif border=0 align=middle>
Kris
stuart1
Post by stuart1 » 19 Jan 2002, 22:17
ITS FIXED!!!!!!!!YES,NEW VALVE OILSEALS AND ALL IS WELL,HAD TO MAKE A SPECIAL TOOL THOUGH SO I COULD DO IT WITHOUT TAKING THE HEAD OFF,BIT OF A CHEW ON BUT WORTH IT NOT TO DISTURB THE HEAD.
