just wondering what might be rquired to fix/get started a 1.1 51 plate 206, if it shows as immobiliser fault causing it to not start,
i havent seen this car yet but i might be interested in purchasing it, and wondered what cost/expense i might be in for
206 non runner
206 non runner
Regards, malcolm.
Re: 206 non runner
ok Adam
not sure when Multiplex came in, i would think being a 51 plate it wont be ?????
Regards, malcolm.
- spider
- My Cars: Soon, I hope...
- x 77
- Contact:
Re: 206 non runner
51 is 99% certain to be plexed, only some unregistered ones floating around back then would of been non plexed*
Typically Y plates are 50/50 on either wiring layout so I'd say its about 90% certain it will be plexed.
*well lights/wipers were sort of plexed on all of them in a fashion.
Without teaching you to suck eggs, favourite initial thought is transponder aerial as sometimes the wiring inside the unit can go a bit bad.
Andy.
Re: 206 non runner
ok thanks Andy
its just i have seen one for sale that might suite her indoors if/when she pass's her driving test,
she passed the one were she drives me up the wall years ago but
they say its a non runner and they plugged there scanner up it and it said imobaliser fault,
realy just wondering if it migh cost a lota or could be easy to fix
Regards, malcolm.
- spider
- x 77
- Contact:
Re: 206 non runner
No problem. I'm sure the wiring would tarnish inside the aerial itself and be a poor connection, I guess there's not a lot to lose with carefully opening it up to check it though.
Same as you I guess, without seeing it its difficult to say but that's my first thought assuming its not decided to "forget" the key or something perhaps because someone whipped the battery leads off while the BSi was awake.
Not really sure what else to suggest as you'll know more than me anyway, another key if one is available is worth trying I guess.
Andy.
