for parts you want to give carparts4less a try - they`re the sister (and cheaper) site to ECP - even uses the same ecp part numbers... example being , pug 2 litre thermostat is £8.44 on ecp , yet its £4.45 on carparts4less.
on and gaiters - i get mine from http://www.jandrcvjoints.co.uk/" onclick="window.open(this.href);return false; mine was £3.
Mot Work
Re: Mot Work
Outstanding - this is exactly why this is a quality forum - thanks for the help - getting the kit posted - all in for a couple of quid
Thanks H
Ross
Thanks H
Ross
Re: Mot Work
Happy days - sorted the driveshaft,ball joint, hub scenario - the front drop link and both rear panhard rods - booked in for 4 wheel alignment and MOT Saturday
But
Started the car and now the ABS light doesn't go out - the only side I have worked on is the front offside - didn't disturb anything on the back doing the panhard rods but all seems to be back where it should be at5 the front end
Clearly time is going to be short now I have the car booked in 11am tomorrow and was hoping someone might have an insight into what might be the problem or offer advice how to identify/locate in a timely fashion what the problem might be - I didn't disconnect anything - just unscrewed the sensor on the hub and replaced it when finished
The last time I had an ABS problem it was on a Xantia and it was just a touch short of hell to resolve.
All
(and by the way - Merry Xmas)
But
All
Re: Mot Work
locate the sensor plug of the one you disasembled and put a ohm meter across it,
or maybe the air gap is full of grease,
regards malcolm
regards malcolm
Re: Mot Work + rear wheel alignment
Happy days all done for another year - thanks for the replies - the ABS issue was a classic - took the road wheel off and found the sensor tied up where I left it - no wonder it didn't work - oooops.
One thing though - the garage said it didn't do the adjustments to the rear wheels despite taking the booking for the 4 wheel alignment - they couldn't advise who locally could either - is the realignment of the rear wheels a major issue or are most garages/tyre centres able to to the work - maybe my garage was having a bad day ?
Re: Mot Work
i would not entrust this kind of work to a tyre/exhaust shop,
regards malcolm
regards malcolm
