central locking problems 306xrdt
philbert
Post by philbert » 20 Feb 2003, 02:47
can anyone help when i use the keyfob to lock the doors the doors lock then unlock its driving me nuts
Edited by - philbert on 20 Feb 2003 18:41:25
woodhead722
Post by woodhead722 » 20 Feb 2003, 05:06
<BLOCKQUOTE id=quote><font size=1 face="Verdana, Arial, Helvetica" id=quote>quote:<hr height=1 noshade id=quote>
<hr height=1 noshade id=quote></BLOCKQUOTE id=quote></font id=quote><font face="Verdana, Arial, Helvetica" size=2 id=quote>
Just a thought.....does this occur on the passenger side as well? If so could it be a problem with one lock/motor only?
philbert
Post by philbert » 21 Feb 2003, 00:43
yeh it happens on all 4 doors
kevin
Post by kevin » 21 Feb 2003, 19:13
Mine had a similar problem with the centeral locking. The fault was traced to corrosion in the wiring harness on the front doors. These were replaced and so far no trouble.
The main reason for failure of these items is water ingress via the windows and sealing strips along the top of the doors.
I also had a similar problem on a Mk3 Astra some years ago, again this was the wiring harness.
Good luck in resolving the trouble
Kevin
