Hi All, I have a 1996 306 DTurbo, my Lucas injector pump's leaking at the top where the throttle linkage comes out (too much veg oil )
I want to fit a veg oil friendly Bosch pump to it, I understand I'll need to get all the pipework and injectors that come with the Bosch pump, my question is, will I need to get a pump off another 1.9 turbo engine or will a non turbo one, or one from say a 1.8 engine work on it??
Is there anything else i'll need to know?
Also, is there an easy way to identify a Bosch pump from a lucas/cav pump?
306 Injector pump swap?
You are lucky that the Lucas pump hasn't gone AWOL... yes you will need the Bosch pipework and injectors. I have a Bosch pre- keypad (ideal) XUD TD pump for £40 + postage from Frogland if you are interested.I want to fit a veg oil friendly Bosch pump to it, I understand I'll need to get all the pipework and injectors that come with the Bosch pump, my question is, will I need to get a pump off another 1.9 turbo engine or will a non turbo one, or one from say a 1.8 engine work on it??
R.I.P. January 2010.
XM 2.1 auto VSX 1996 - Bosch Inj, Xantia HDi 90 estate 1999, Xantia 1.9TD 1997
Previously...
GS 1970, Dyane 1974, Xantia 94 VSX TD, XM 94, 2.1 auto - Lucas Inj, XM 92 2.1 estate - Lucas Inj
Previously...
YesI've got a keypad immobilisor on mine but i've unplugged it, will it work?
NoAnd do you have any of the pipework to go with it?
Previously...
Previously...
Errr...
I´ve lost something here...
LoL you write that the keypad would be allright with a different pump ?
That would only be true if you have the correct code to go with the antitheft device on the pump ?
Or is it the body computer communicating with the antitheft device on the pump - therefore nothing is in fact changed - viewed from the antitheft system ?
Reason I ask is a previous discussion on a danish forum where we were at a loss on how to deal with pump changes for DIY repairs.
Breedsey - the earlier non-electronic Bosch pump piping & injectors should fit. They have been used on numerous Peugeot models over the years with same basic engine type (XUD)
Anders (DK) - '90 BX16Image
As far as i understand it, as long as the immobilisor's telling the pump to run, it'll run, the code part is in the car part of it.AndersDK wrote:
I'd heard somewhere that the pipework is different on the bosch pump, so you're saying the bosch pump is a straight swap for my lucas one?AndersDK wrote: Breedsey - the earlier non-electronic Bosch pump piping & injectors should fit. They have been used on numerous Peugeot models over the years with same basic engine type (XUD)
WITHOUT the keypad Anders, which is a pain in the arseErrr...
Previously...
Previously...
All's well that ends well! Good news - are you saying that you are still running Lucas injectors with the Bosch pump?All done now, cheers for the advice, i got a bosch pump off an N reg (1995?)306 D turbo the same as mine, it didn't have a keypad so wasn't a problem.
Only swapped the pump, mounting bracket and injector pipes, didn't do the injectors, and it runs fine.
Previously...
Previously...
