I have just bought a 1999 406 petrol 1.8. I have notcied the thermostat housing is leaking coolant between the engine and the housing. Is there a gasket that should be used to seal it, or can I fix the leak by removing it and using some sealant on the join?
If so, what sealant should I use?
thanks,
David.
Thermostat gasket
