peug 2.1 td revs going up and down when idling
Hi guys
i seem to be having a problem sometimes when i start the car up. The engine seems to be revving up and down and sometimes just goes up so i have to switch off the engine quickly. Its quite random but switching the car on and off a few times cures the problem until it re-occurs
any ideas what the problem could be
peug 406 2.1td P reg
seems to be a electronic pump where the accelarator cable goes into a box near the battery.
Thanks.
Zab.
Thanks.
Zab.
2005 ZX SX Diesel 64K
2004 ZX Aura TD 150k
2003 ZX Volcane TD 124k
Agree on the air problem.
It is by far the most common problem on diesel engines.
The rotary diesel fuel distributor pump does not accept even the slightest amount of air in the incoming fuel. It upsets the volumetric regulation of the fuel.
Look for any suspect fuel line : surface hairline cracks on rubber hoses, split hoses at studs, especially the overrun hoses at the injectors.
And its both the feed & return lines to/fro the tank.
The filter/heater bowl is also to be suspected.
A good trick is to replace the very last run of fuel hose going into the pump with a clear hose. This way you can instantly see if you have sorted the problem, as any air will be visible as bubbles.
I urge you to do this before you invest in any replacement components or garage labour.
Anders (DK) - '90 BX16Image
Does anyone know where I could get clear plastic fuel line from?
Cause I'm having a very similar problem.
So far have used silicon but that won't last forever, and has already changed it bore, upwards thankfully.
2001 406 Rapier 2.0 HDi 90 Estate - Sold Scrap after being viciously attacked by a falling tree
2001 Toyota MR2 1.8 VVTi - To be sold for spares/repair - dead gearbox
2014 Seat Ibiza Eastate 1.4 FR ACT (bought in an emergency, but a nice enough low mileage car)
Its PVC hosing -
Used everyhwere you have to move fluid any kind :
1) campers & boats for drinking water and waste water
2) cars for fuel & vacuum sensing in general
3) industri for oils and air supply
4) home & garden for garden hoses and laundry machines
Available in almost any thinkable diameter and wall thickness.
ive taken a look at mine it is clear plastic which is covered in dirt but cant seem to see any air gaps yet i suppose il have to take a look when the problem occurs.
as per the thread by the chap with the 306 mines different as if blip the throttle the revs just go higher and still jump up and down
- My Cars: 2010 Citroen C5-X7 tourer
1998 Citroen Saxo 1.5D
2018 Citroen C4-B7
1998 Peugeot 306. 1.9D
2011 Citroen C1 - x 72
- Contact:
If air is getting in, you'll see the air bubbles passing through the pipe when the engine is running - or even if you squeeze the primer bulb without the engine running. Don't rule out the primer bulb from having a slight leak.
2010 C5 X7 VTR+Nav 160
1998 1.5 Saxo
1998 Pug 306 1.9D
2018 C4 B7 VTR+
2011 Citroen C1
1998 1.5 Saxo
1998 Pug 306 1.9D
2018 C4 B7 VTR+
2011 Citroen C1
hi guys this is still happening but not only when i start up nw last 2 mornings when ive started car has been fine as soon as i got to the bottom of the road and stood still in traffic it would start idling erraticaly either a switch off/on would cure or pressing rev pedal a few times would help
ive read somewhere it could be the idle air control valve ?
anybody know where this would be on the 21.td engine ?
On a good old TD ? 8)davethewheel wrote:could be the engine temp sensor it's a green sensor on the right hand side of the cylinder head, i've heard of a few of these packing up and causing the revs to fluctuate, it's worth a try and the sensor is only around £8.00 from the dealers
AndersDK wrote:On a good old TD ? 8)davethewheel wrote:could be the engine temp sensor it's a green sensor on the right hand side of the cylinder head, i've heard of a few of these packing up and causing the revs to fluctuate, it's worth a try and the sensor is only around £8.00 from the dealers
yes all the peugeot 2.1td's and xantia 2.1td's have this sensor.
regards dave
