Clutch Adjustment
doug
Clutch Adjustment
Post by doug » 17 May 2001, 04:01
Can anyone advise me on how to adjust the clutch mechanism, so that the pedal movement is lighter.
JohnD
donor 2019
x 41
Clutch Adjustment
Post by JohnD » 18 May 2001, 00:22
Hi Doug. - The clutch pedal should be adjusted so that between the pedal pad, pressed to the floor and it's 'up' position you have a distance of around 140mm. If it's not within 5mm either way, the adjustment should be carried out at the clutch housing. To reduce drag to the minimum make sure the pedal pivot is lubricated and the inner cable not damaged.
