Hi All,
I have a 95' 106 XN 1.0. Its coming up to 80,000 miles, which according to Peugeot's website means Service C time.
I've been umming and arring about getting it done. I don't need everything doing, I got the cambelt changed at 72,000, I did the air filter and oil change myself at Christmas etc. I've just tried to do the spark plugs, and I've done three, but I'm buggered if I can get the fourth out!
So, should I be getting the service done ASAP? Or given the age of the car, am I better off forgetting about it and just running it into the ground as it were? Or are bits gonna start to fall off v. soon if I don't get it done
Am I worrying too much about Servicing?
Regards
Joe
Joe
Hi There,
I've already done the air filter, changed the oil filter at christmas, done 3 of the spark plugs (can't get the fourth to bloody budge!!!) and the cambelt has been done recently too.
So, not alot needs doing. However whats more worrying is I found a load of mayonnaise under the oil filler cap today
However the cars been doing really short journeys. And also, this must have been in the last month, after I changed the spark plugs, as I checked it then and it was fine. So I'm wondering if its something I've done. I've checked the coolant levels, which are the same, the dipstick oil is coming out fine, and when I stuck my finger under the cap area inside the crank case cover, the mayonnaise seemed to stop after about half a finger...so I'm praying its just condensation!
If I take it to a garage, can they test the coolant for hydrocarbons? I've heard this will tell me whether it has blown or not, for sure.
Regards
Joe
Joe
Hi Mate,nxh66 wrote:My 1.4i zx gets mayo too with a lot of short runs and never looses any coolant, has been like it ever since i got the car 40,000k ago. Normally find it all dissapears with a good long thrash down the motorway!!
Thanks for your support - so far this is what I've found. Took it on a 400 mile round trip and they mayo has disappeared!
The service is on my list of things to do. However the brakes were done at the MOT because there was a problem with the back brakes not performing as spec, so hopefull there won't be any problems with those!
Regards
Joe
Joe
