i wonder if anyone could give me some advice--i've been offered a peugeot 306xsi quite cheap but when driving it the gear lever seems to rock backward and forwards--it's not too bad but i don't want to commit if it's an expensive fix-the owner says he thinks it's a tyre problem but i was thinking gearbox mounting--any ideas on problem and price to fix?
thanks in advance
help! 306xsi gear lever rocking--sorted!
i'm still struggling for ideas if anyone can help-my mate took this car to a garage and they replaced the bottom arm and tracked it up, charging him £120 and it hasn't fixed it or made a difference--i've now bought the car from him and notice that when the shaking is bad if i dip the clutch, the shaking goes, is a mounting still a possibility?
does anyone know an expert in the Leicester area who can diagnose and fix? i just can't afford to chuck money at it if it doesn't cure it--thanks for any help!
- Contact:
Probably is the engine mounts. Is there a lower stabiliser one on the subframe, kinda looks round with a bracket going through it. That was shot on my Visa, the rubber breaks up and so the engine was rocking around, put a solid one in and fine. Probably only a hours job in a garage. You want to look at the engine and rev it manually or get someone to do it and see how much its moving. Shouldnt really rock back and forth more than half an inch. When the engines not running you could try rocking it yourself as well.
- Contact:
